DeWalt DW660 Motor Brushes Replacement
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: step 1, image 1 of 2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: step 1, image 2 of 2
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: step 2, image 1 of 3 DeWalt DW660 Motor Brushes Replacement: step 2, image 2 of 3 DeWalt DW660 Motor Brushes Replacement: step 2, image 3 of 3
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: step 3, image 1 of 2 DeWalt DW660 Motor Brushes Replacement: step 3, image 2 of 2
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: step 4, image 1 of 2 DeWalt DW660 Motor Brushes Replacement: step 4, image 2 of 2
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: step 5, image 1 of 2 DeWalt DW660 Motor Brushes Replacement: step 5, image 2 of 2
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
Joseph Pacitto
239 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 1,426
