DeWalt DW920 Lock Switch Replacement
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: step 1, image 1 of 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: step 2, image 1 of 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: step 3, image 1 of 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: step 4, image 1 of 1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: step 5, image 1 of 2 DeWalt DW920 Lock Switch Replacement: step 5, image 2 of 2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Stephen Rada
433 Reputation
4 Guides authored
One Comment
This guide was descriptive and easy to follow. Good job!
DankMemerino - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 286
