DeWalt DW920 Motor Replacement
  1. DeWalt DW920 Motor Replacement, Disassembly: step 1, image 1 of 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: step 2, image 1 of 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: step 3, image 1 of 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: step 4, image 1 of 1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: step 5, image 1 of 1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: step 6, image 1 of 1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Stephen Rada
433 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 829
