DeWalt DW936 Trigger Replacement
  1. DeWalt DW936 Trigger Replacement, Plastic Cover: step 1, image 1 of 1
    • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
  2. DeWalt DW936 Trigger Replacement: step 2, image 1 of 1
    • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
  3. DeWalt DW936 Trigger Replacement: step 3, image 1 of 1
    • Remove Allen Key.
  4. DeWalt DW936 Trigger Replacement: step 4, image 1 of 1
    • Unscrew the black plastic knob underneath the trigger.
  5. DeWalt DW936 Trigger Replacement: step 5, image 1 of 1
    • Grab hold of the black air filter portion and pull off.
  6. DeWalt DW936 Trigger Replacement: step 6, image 1 of 1
    • This is what the inside of the saw looks like.
  7. DeWalt DW936 Trigger Replacement, Trigger: step 7, image 1 of 1
    • The trigger has black and white wires coming off of it. Grip the trigger with both hands, one on the plastic trigger part and the other on the plastic by the silver metal piece.
    • Pull up.
  8. DeWalt DW936 Trigger Replacement: step 8, image 1 of 1
    • The trigger should be able to sit freely.
  9. DeWalt DW936 Trigger Replacement: step 9, image 1 of 2 DeWalt DW936 Trigger Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Lift off the silver metal piece using tweezers.
    • Lift off each hook. (4 corners)
  10. DeWalt DW936 Trigger Replacement: step 10, image 1 of 1
    • Pull plastic trigger out of the black plastic casing.
2 other people completed this guide.
Scott Weinhardt
603 Reputation
5 Guides authored
Cal Poly, Team 8-2, Banghart Winter 2017 Member of Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Members
5 Guides authored
One Comment
Then repair trigger by stripping,cleaning,soldering and whatever else before replacing to unit as you can no longer buy the part as it is obsolete!
donald.mcguinnes - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 725
