DeWalt DW997 Speed Switch Replacement
  1. DeWalt DW997 Speed Switch Replacement, Speed Switch: step 1, image 1 of 2 DeWalt DW997 Speed Switch Replacement, Speed Switch: step 1, image 2 of 2
    • Remove seven 21 mm Torx T15 screws.
    • Remove one 18 mm Torx T10 screw.
    • After removing all screws, lift up the top yellow cover.
    • The yellow cover should easily lift up, if not, check for unscrewed screws.
    • Do not pry the two yellow covers apart, they can crack.
  2. DeWalt DW997 Speed Switch Replacement: step 2, image 1 of 1
    • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
  3. DeWalt DW997 Speed Switch Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
  4. DeWalt DW997 Speed Switch Replacement: step 4, image 1 of 1
    • Remove the other leg manually, it should easily come out.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 2,078
