DeckLink HD Extreme 3D+ Fan Replacement
  1. DeckLink HD Extreme 3D+ Fan Replacement, Before and after: step 1, image 1 of 2 DeckLink HD Extreme 3D+ Fan Replacement, Before and after: step 1, image 2 of 2
    • Original fan.
    • Replaced fan. 40mm square.
  2. DeckLink HD Extreme 3D+ Fan Replacement, Connector: step 2, image 1 of 1
    • Remember the cable colors at the connector and which position they are!
    • WARNING: Be carefull here. I did choose to trial and error to find the solution. But you might break your PC or the board.
  3. DeckLink HD Extreme 3D+ Fan Replacement, Take off the fan: step 3, image 1 of 2 DeckLink HD Extreme 3D+ Fan Replacement, Take off the fan: step 3, image 2 of 2
    • Take out these 4 screws.
    • Disconnect the micro JST.
  4. DeckLink HD Extreme 3D+ Fan Replacement, Replacement parts: step 4, image 1 of 1
    • Get all your replacement parts around.
  5. DeckLink HD Extreme 3D+ Fan Replacement: step 5, image 1 of 2 DeckLink HD Extreme 3D+ Fan Replacement: step 5, image 2 of 2
    • My replacement JST came in a different color order.
    • I assumed the fan I bought would have the same colored connection as the original one. Result: positive.
    • So I did switch the black with the red color. But be sure to check which cable colors your JSTs come with and which order they have.
    • Check step 2: Remember the connection order. You might break something.
    • The connectors have to match with the board. Otherwise the fan is spinning the wrong direction.
  6. DeckLink HD Extreme 3D+ Fan Replacement, Isolate the connection: step 6, image 1 of 1
    • Be sure to isolate the connection.
  7. DeckLink HD Extreme 3D+ Fan Replacement, Bring on the fan: step 7, image 1 of 3 DeckLink HD Extreme 3D+ Fan Replacement, Bring on the fan: step 7, image 2 of 3 DeckLink HD Extreme 3D+ Fan Replacement, Bring on the fan: step 7, image 3 of 3
    • Tighten the fan carefully.
    • Make sure it sits well and is tight! Otherwise you get movement noise.
    • I know, mine isn't perfectly aligned. But is does work for me.
Simeon
512 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 34
All Time: 877
