Definitive Technology W7 Motherboard Replacement
  1. Definitive Technology W7 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Definitive Technology W7 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Definitive Technology W7 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
    • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
    • Use the metal spudger to remove all rubber feet.
    • Unscrew all four screws from under the rubber feet.
    • These screws will be approximately 35 mm in length.
    • You can now use the prying tool to pry the bottom panel off the speaker.
  2. Definitive Technology W7 Motherboard Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
    • These screws are approximately 8 mm in length.
  3. Definitive Technology W7 Motherboard Replacement: step 3, image 1 of 2 Definitive Technology W7 Motherboard Replacement: step 3, image 2 of 2
    • Push up the locking tabs on the sides of the ribbon cable connector.
    • Gently pull the ribbon cable out from the connector to remove it.
  4. Definitive Technology W7 Motherboard Replacement: step 4, image 1 of 2 Definitive Technology W7 Motherboard Replacement: step 4, image 2 of 2
    • Tilt the motherboard outwards from the speaker.
    • Remove all five connectors from the motherboard.
    • Remove the motherboard from the speaker.
  5. Definitive Technology W7 Motherboard Replacement: step 5, image 1 of 2 Definitive Technology W7 Motherboard Replacement: step 5, image 2 of 2
    • Using the Phillips #2 screwdriver, remove the three screws from the network card.
    • These screws are approximately 8mm in length.
    • Remove the network card from the motherboard.
Magnus Maillet
171 Reputation
1 Guide authored
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 275
