Definitive Technology W7 Speaker Replacement
  1. Definitive Technology W7 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Use the metal spudger to pry off the panel at the top of the device.
    • The top panel has the device logo in the center.
    • Use the flat end of the metal spudger and place it between the gaps of the top panel and slowly pry the panel off.
  2. Definitive Technology W7 Speaker Replacement: step 2, image 1 of 1
    • Remove the thirteen Phillips #0 screws.
  3. Definitive Technology W7 Speaker Replacement: step 3, image 1 of 1
    • Remove the black panel.
  4. Definitive Technology W7 Speaker Replacement: step 4, image 1 of 2 Definitive Technology W7 Speaker Replacement: step 4, image 2 of 2
    • After you remove the black panel, you will see that the device is covered with a gray mesh, secured with a drawstring.
    • Flick the switch on the middle of the lock down to loosen the sack.
  5. Definitive Technology W7 Speaker Replacement: step 5, image 1 of 1
    • After you have flicked the switch loosen the sack and pull the sack down which will reveal the speaker.
  6. Definitive Technology W7 Speaker Replacement: step 6, image 1 of 1
    • Remove the four screws on top of the device on each corner with a Phillips #0 screwdriver.
  7. Definitive Technology W7 Speaker Replacement: step 7, image 1 of 1
    • Gently lift the top cover off the device.
  8. Definitive Technology W7 Speaker Replacement: step 8, image 1 of 1
    • If you now look inside the device, you will see the speaker which is the large cylinder on the inner side of the device.
  9. Definitive Technology W7 Speaker Replacement: step 9, image 1 of 2 Definitive Technology W7 Speaker Replacement: step 9, image 2 of 2
    • Remove the four Phillips #0 screws around the speaker holding it in place.
    • Now lay the device on its side with the speaker facing upward, then unscrew the screws around the speaker.
  10. Definitive Technology W7 Speaker Replacement: step 10, image 1 of 1
    • Stand the device upright and carefully pull the speaker out of the device with the wires still intact.
  11. Definitive Technology W7 Speaker Replacement: step 11, image 1 of 1
    • Now grab the end of the wire connecting the device to the speaker itself.
    • Slowly and carefully pull the wires away from the speaker.
Jamari Brewster
193 Reputation
1 Guide authored
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 19
All Time: 528
