Dell Inspiron 15-7569 Memory Modules Replacement
  1. Dell Inspiron 15-7569 Memory Modules Replacement, Lifting the Mylar: step 1, image 1 of 1
  2. Dell Inspiron 15-7569 Memory Modules Replacement, Popping up the Memory Module: step 2, image 1 of 1
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  3. Dell Inspiron 15-7569 Memory Modules Replacement, Remove the Memory Module: step 3, image 1 of 1
    • Remove the memory module from the memory-module slot.
  4. Dell Inspiron 15-7569 Memory Modules Replacement, Lifting the Mylar: step 4, image 1 of 1
    • Lift the Mylar to access the memory-module slot.
  5. Dell Inspiron 15-7569 Memory Modules Replacement, Align the Notch: step 5, image 1 of 2 Dell Inspiron 15-7569 Memory Modules Replacement, Align the Notch: step 5, image 2 of 2
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  6. Dell Inspiron 15-7569 Memory Modules Replacement, Sliding the Memory Module: step 6, image 1 of 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Finish Line
Terrence15
79,888 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,994 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 283
