Dell Inspiron 15-7569 Motherboard Replacement
  1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: step 1, image 1 of 3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: step 1, image 2 of 3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: step 1, image 3 of 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
    • Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
    • Remove the fan from the motherboard.
  3. Dell   Inspiron  15-7569 Motherboard Replacement: step 3, image 1 of 3 Dell   Inspiron  15-7569 Motherboard Replacement: step 3, image 2 of 3 Dell   Inspiron  15-7569 Motherboard Replacement: step 3, image 3 of 3
    • Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
    • Remove the black speaker wire.
    • Remove the white display wire.
  4. Dell   Inspiron  15-7569 Motherboard Replacement: step 4, image 1 of 3 Dell   Inspiron  15-7569 Motherboard Replacement: step 4, image 2 of 3 Dell   Inspiron  15-7569 Motherboard Replacement: step 4, image 3 of 3
    • (Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
    • Remove the gold and silver display cables.
    • Remove the white fan cable.
    • Remove the USB-to-motherboard cable
  5. Dell   Inspiron  15-7569 Motherboard Replacement: step 5, image 1 of 2 Dell   Inspiron  15-7569 Motherboard Replacement: step 5, image 2 of 2
    • Remove the black battery cable.
    • Remove the blue ribbon cable.
    • Unscrew and remove hard drive/SSD.
    • Disconnect the hard drive/SSD from the motherboard.
  6. Dell   Inspiron  15-7569 Motherboard Replacement: step 6, image 1 of 2 Dell   Inspiron  15-7569 Motherboard Replacement: step 6, image 2 of 2
    • Gently remove the motherboard from the device.
Matthew Clements
546 Reputation
5 Guides authored
USF Tampa, Team S5-G4, Walkup Fall 2017 Member of USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 1,567
