Dell 3100 (Touch) Battery Replacement
  1. Dell 3100 (Touch) Battery Replacement, Detach Bottom Cover: step 1, image 1 of 2 Dell 3100 (Touch) Battery Replacement, Detach Bottom Cover: step 1, image 2 of 2
    • Unscrew the nine PH#0 captive screws on the bottom of the device.
    • Use a pick to run along the outside of the device popping all the clips. Prying should not be necessary.
  2. Dell 3100 (Touch) Battery Replacement, Unplug the battery: step 2, image 1 of 2 Dell 3100 (Touch) Battery Replacement, Unplug the battery: step 2, image 2 of 2
    • Pull carefully, but firmly, on the battery cable until it becomes detached.
  3. Dell 3100 (Touch) Battery Replacement, Remove the battery: step 3, image 1 of 1
    • Remove these three M2x5 screws and take the battery out
    • If your replacement battery doesn't come with a cable, you will need to remove the cable from the old battery before disposing of it.
    • DO NOT throw batteries in the trash. Take them to a proper battery recycling center.
  4. Dell 3100 (Touch) Battery Replacement, Battery: step 4, image 1 of 2 Dell 3100 (Touch) Battery Replacement, Battery: step 4, image 2 of 2
    • Use a plastic spudger to lift up the flap. Use the flap to pull the connector straight away from the board (towards the battery).
  5. Dell 3100 (Touch) Battery Replacement: step 5, image 1 of 1
    • Remove 3 M2x4 screws
  6. Dell 3100 (Touch) Battery Replacement: step 6, image 1 of 3 Dell 3100 (Touch) Battery Replacement: step 6, image 2 of 3 Dell 3100 (Touch) Battery Replacement: step 6, image 3 of 3
    • Use a spudger to detach the tab, and pull the tab up away from the device. This will break the adhesive holding in the battery.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 157
