Dell AC511 Hanger Replacement
  1. Dell AC511 Hanger Replacement, Front Panel: step 1, image 1 of 3 Dell AC511 Hanger Replacement, Front Panel: step 1, image 2 of 3 Dell AC511 Hanger Replacement, Front Panel: step 1, image 3 of 3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Hanger Replacement: step 2, image 1 of 2 Dell AC511 Hanger Replacement: step 2, image 2 of 2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Hanger Replacement: step 3, image 1 of 2 Dell AC511 Hanger Replacement: step 3, image 2 of 2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Hanger Replacement, Hanger: step 4, image 1 of 2 Dell AC511 Hanger Replacement, Hanger: step 4, image 2 of 2
    • The speakers do not have to have been removed for this step, though it may make it easier.
    • Remove the screws from the hangers you are looking to replace using a JIS #1 screwdriver.
    • We accidentally removed some of the rubber lining the inside along with the hanger. Use a razor to cut it off before removing the hanger.
William Cook
653 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 213
