Dell Adamo 13 Dell Solid State Drive Replacement
  1. Dell Adamo 13 Dell Solid State Drive Replacement, Battery: step 1, image 1 of 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Dell Solid State Drive Replacement: step 2, image 1 of 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Dell Solid State Drive Replacement: step 3, image 1 of 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Dell Solid State Drive Replacement, SSD: step 4, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws securing the SSD to the motherboard.
Joshua Turner
73 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 235
