Dell Adamo 13 Keyboard Replacement
  1. Dell Adamo 13 Keyboard Replacement, Battery: step 1, image 1 of 1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Dell Adamo 13 Keyboard Replacement: step 2, image 1 of 1
    • Remove the bottom cover by unsnapping the clips around the edge of the computer.
    • You may hear a slight pop when you pull the cover off.
  3. Dell Adamo 13 Keyboard Replacement: step 3, image 1 of 1
    • Disconnect orange film wire harness from the slot it is connected to.
    • The bottom cover and battery are one piece and will be replaced as a unit.
    • Remove the battery from the device.
  4. Dell Adamo 13 Keyboard Replacement, Motherboard: step 4, image 1 of 1
    • Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
  5. Dell Adamo 13 Keyboard Replacement: step 5, image 1 of 3 Dell Adamo 13 Keyboard Replacement: step 5, image 2 of 3 Dell Adamo 13 Keyboard Replacement: step 5, image 3 of 3
    • Remove all the connections to the circuit board on top and underneath.
    • Use caution when removing connections to prevent damage.
    • Remove the motherboard from the device.
  6. Dell Adamo 13 Keyboard Replacement, Keyboard: step 6, image 1 of 1
    • Using the Phillips #0 screwdriver, remove eight 2 mm screws securing the keypad to the device.
  7. Dell Adamo 13 Keyboard Replacement: step 7, image 1 of 2 Dell Adamo 13 Keyboard Replacement: step 7, image 2 of 2
    • Gently lift the keypad out of the laptop mainframe.
Tyler Pourmand
85 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 12
All Time: 175
