Dell Alienware 13 Base Panel Replacement
  1. Dell Alienware 13 Base Panel Replacement, Base Panel: step 1, image 1 of 1
    • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
    • Close the device and turn the device over.
  2. Dell Alienware 13 Base Panel Replacement: step 2, image 1 of 1
    • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
    • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
  3. Dell Alienware 13 Base Panel Replacement: step 3, image 1 of 3 Dell Alienware 13 Base Panel Replacement: step 3, image 2 of 3 Dell Alienware 13 Base Panel Replacement: step 3, image 3 of 3
    Tool used on this step:
    Heavy-Duty Spudger
    Buy
2 other people completed this guide.
Adam Russell
898 Reputation
6 Guides authored
USF Tampa, Team 14-2, Eyestone Fall 2016 Member of USF Tampa, Team 14-2, Eyestone Fall 2016
USFT-EYESTONE-F16S14G2
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 29
All Time: 746
