Dell Alienware 13 R3 System Board Replacement
  1. Dell Alienware 13 R3 System Board Replacement, Loosen the Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Loosen the five captive screws that secure the base cover to the computer base.
  2. Dell Alienware 13 R3 System Board Replacement, Pry the Base Cover: step 2, image 1 of 1
    • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
  3. Dell Alienware 13 R3 System Board Replacement, Lift the Base Cover: step 3, image 1 of 1
    • Lift the base cover off the computer base.
  4. Dell Alienware 13 R3 System Board Replacement, Disconnect the Battery Cable: step 4, image 1 of 1
    • Using a plastic scribe, disconnect the battery cable from the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Connect the battery cable to the system board.
  5. Dell Alienware 13 R3 System Board Replacement, Slide the Tabs: step 7, image 1 of 1
    • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
  6. Dell Alienware 13 R3 System Board Replacement, Tighten the Five Captive Screws: step 8, image 1 of 1
    • Tighten the five captive screws that secure the base cover to the computer base.
  7. Dell Alienware 13 R3 System Board Replacement, Align the Notch: step 9, image 1 of 1
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
  8. Dell Alienware 13 R3 System Board Replacement, Lift the Wireless-Card Bracket: step 10, image 1 of 1
    • Lift the wireless-card bracket off the wireless card.
  9. Dell Alienware 13 R3 System Board Replacement, Disconnecting the Antenna Cables: step 11, image 1 of 1
    • Disconnect the antenna cables from the wireless card.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
    • Slide the NEW wireless card at an angle into the wireless-card slot.
    • Connect the antenna cables to the wireless card.
  10. Dell Alienware 13 R3 System Board Replacement, Align the Screw Hole: step 15, image 1 of 1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
  11. Dell Alienware 13 R3 System Board Replacement, Replace the Screw: step 16, image 1 of 1
    • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
  12. Dell Alienware 13 R3 System Board Replacement, Remove the Screw: step 17, image 1 of 1
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  13. Dell Alienware 13 R3 System Board Replacement, Lift and Slide the Solid-State Drive: step 18, image 1 of 1
    • Lift and slide the solid-state drive from the solid-state drive slot.
    • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
  14. Dell Alienware 13 R3 System Board Replacement, Press the Memory Module: step 20, image 1 of 1
    • Press the memory module down until it clicks into place.
  15. Dell Alienware 13 R3 System Board Replacement, Popping up the Memory Module: step 21, image 1 of 1
    • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
  16. Dell Alienware 13 R3 System Board Replacement, Remove the Memory Module: step 22, image 1 of 1
    • Slide and remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
  17. Dell Alienware 13 R3 System Board Replacement, Press the Memory Module Down: step 24, image 1 of 1
  18. Dell Alienware 13 R3 System Board Replacement, Remove the Screws: step 25, image 1 of 1
    • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  19. Dell Alienware 13 R3 System Board Replacement, Using a Plastic Scribe: step 26, image 1 of 1
    • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
    • Slide and remove the rear-I/O cover from the computer base.
  20. Dell Alienware 13 R3 System Board Replacement, Sliding the Rear-I/O: step 28, image 1 of 1
    • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
    • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
  21. Dell Alienware 13 R3 System Board Replacement, Remove the Screws: step 30, image 1 of 1
    • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  22. Dell Alienware 13 R3 System Board Replacement, Remove the Screw: step 31, image 1 of 1
    • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
  23. Dell Alienware 13 R3 System Board Replacement, Remove the Two Screws: step 32, image 1 of 1
    • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  24. Dell Alienware 13 R3 System Board Replacement, Lift the Computer Base: step 33, image 1 of 1
    • Lift the computer base from the palm-rest assembly.
  25. Dell Alienware 13 R3 System Board Replacement, Align the Screw Holes: step 34, image 1 of 1
    • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
    • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
    • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
    • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
  26. Dell Alienware 13 R3 System Board Replacement, Disconnecting the Coin-Cell Battery: step 38, image 1 of 1
    • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
    • Disconnect the coin-cell battery cable from the system board.
  27. Dell Alienware 13 R3 System Board Replacement, Peeling the Coin-Cell Battery: step 39, image 1 of 1
    • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
  28. Dell Alienware 13 R3 System Board Replacement, Adhere the Coin-Cell Battery: step 40, image 1 of 1
    • Adhere the NEW coin-cell battery to the palm-rest assembly.
    • Connect the coin-cell battery cable to the system board.
  29. Dell Alienware 13 R3 System Board Replacement, Peeling the Keyboard Connector: step 42, image 1 of 1
  30. Dell Alienware 13 R3 System Board Replacement, Lifting the Battery: step 43, image 1 of 1
    • Lift the battery off the palm-rest assembly.
  31. Dell Alienware 13 R3 System Board Replacement, Placing the New Battery: step 44, image 1 of 1
    • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
    • Using the alignment post, place the NEW battery on the palm-rest assembly.
  32. Dell Alienware 13 R3 System Board Replacement, Adhering the Keyboard: step 45, image 1 of 1
    • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
  33. Dell Alienware 13 R3 System Board Replacement, Disconnect the Left-Fan Cable: step 46, image 1 of 1
    • WARNING: The heat sink may become hot during normal operation. Allow sufficient time for the heat sink to cool before you touch it.
    • CAUTION: For maximum cooling of the processor, do not touch the heat transfer areas on the heat sink. The oils in your skin can reduce the heat transfer capability of the thermal grease.
    • Disconnect the left-fan cable from the system board.
  34. Dell Alienware 13 R3 System Board Replacement, Disconnecting the Right-Fan Cable: step 47, image 1 of 1
    • Disconnect the right-fan cable from the system board.
  35. Dell Alienware 13 R3 System Board Replacement, Remove the Seven Screws: step 48, image 1 of 1
    • In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Lift the heat-sink assembly off the system board.
  36. Dell Alienware 13 R3 System Board Replacement, Align the Screw Holes: step 50, image 1 of 1
    • CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
    • NOTE: The original thermal grease can be reused if the original system board and fan are reinstalled together. If either the system board or the fan is replaced, use the thermal pad provided in the kit to ensure that thermal conductivity is achieved.
    • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
    • In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
    • Connect the right-fan cable to the respective connector on the system board.
    • Connect the left-fan cable to the respective connector on the system board.
  37. Dell Alienware 13 R3 System Board Replacement, Turn the Computer Over: step 54, image 1 of 1
    • NOTE: Your computer’s Service Tag is stored in the system board. You must enter the Service Tag in the BIOS setup program after you replace the system board.
    • NOTE: Replacing the system board removes any changes you have made to the BIOS using the BIOS setup program. You must make the appropriate changes again after you replace the system board.
    • NOTE: Before disconnecting the cables from the system board, note the location of the connectors so that you can reconnect the cables correctly after you replace the system board.
    • CAUTION: Place the computer on a clean, flat surface.
    • Turn the computer over.
  38. Dell Alienware 13 R3 System Board Replacement, Disconnecting the Logo-Board Cable: step 55, image 1 of 1
    • Disconnect the logo-board cable from the system board.
  39. Dell Alienware 13 R3 System Board Replacement, Disconnecting the Power-Button Board Cable: step 56, image 1 of 1
    • Using the pull-tab, disconnect the power-button board cable from the system board.
  40. Dell Alienware 13 R3 System Board Replacement, Open the Latch: step 57, image 1 of 1
    • Open the latch and disconnect the display cable from the system board.
  41. Dell Alienware 13 R3 System Board Replacement, Turn the Computer Over: step 58, image 1 of 1
  42. Dell Alienware 13 R3 System Board Replacement, Remove the Screw: step 59, image 1 of 1
    • Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
    • Disconnect the power-adapter port cable from the system board.
  43. Dell Alienware 13 R3 System Board Replacement, Disconnect the Speaker Cable: step 61, image 1 of 1
    • Disconnect the speaker cable from the system board.
  44. Dell Alienware 13 R3 System Board Replacement, Open the Latch: step 62, image 1 of 1
    • Open the latch and disconnect the keyboard cable from the system board.
  45. Dell Alienware 13 R3 System Board Replacement, Open the Latch: step 63, image 1 of 1
    • Open the latch and disconnect the keyboard-backlight cable from the system board.
  46. Dell Alienware 13 R3 System Board Replacement, Disconnect the Touch-Pad Cable: step 64, image 1 of 1
    • Open the latch and disconnect the touch-pad cable from the system board.
  47. Dell Alienware 13 R3 System Board Replacement, Remove the Screw: step 65, image 1 of 1
  48. Dell Alienware 13 R3 System Board Replacement, Remove the two Screws: step 66, image 1 of 1
    • Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
  49. Dell Alienware 13 R3 System Board Replacement, Lift the System Board: step 67, image 1 of 1
    • Lift the system board off the palm-rest assembly.
  50. Dell Alienware 13 R3 System Board Replacement, Align the Screw Holes: step 68, image 1 of 1
    • CAUTION: Ensure that no cables are under the system board.
    • Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
  51. Dell Alienware 13 R3 System Board Replacement, Replace the Two Screws: step 69, image 1 of 1
    • Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
  52. Dell Alienware 13 R3 System Board Replacement, Align the Screw Hole: step 70, image 1 of 1
    • Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
  53. Dell Alienware 13 R3 System Board Replacement, Replace the Screw: step 71, image 1 of 1
    • Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
    • Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
  54. Dell Alienware 13 R3 System Board Replacement, Sliding the Keyboard-Backlight: step 73, image 1 of 1
    • Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
  55. Dell Alienware 13 R3 System Board Replacement, Slide the Keyboard Cable: step 74, image 1 of 1
    • Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
    • Connect the speaker cable to the system board.
    • Connect the power-adapter port cable to the system board.
  56. Dell Alienware 13 R3 System Board Replacement, Turn the Computer Over: step 77, image 1 of 1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
    • Connect the power-button board cable to the system board.
    • Connect the logo-board cable to the system board.
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 661
