Dell Alienware 14 Battery Replacement
  1. Dell Alienware 14 Battery Replacement, Close the Display: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Dell Alienware 14 Battery Replacement, Remove the Screws: step 2, image 1 of 2 Dell Alienware 14 Battery Replacement, Remove the Screws: step 2, image 2 of 2
    • Remove the screws that secure the base cover to the computer base.
  3. Dell Alienware 14 Battery Replacement, Slide and Lift the Base Cover: step 3, image 1 of 1
    • Slide and lift the base cover off the computer base.
  4. Dell Alienware 14 Battery Replacement, Align the Tabs: step 4, image 1 of 1
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Dell Alienware 14 Battery Replacement, Replace the Screws: step 5, image 1 of 1
    • Replace the screws that secure the base cover to the computer base.
  6. Dell Alienware 14 Battery Replacement, Turn the Computer Over: step 6, image 1 of 1
    • Turn the computer over and open the display.
  7. Dell Alienware 14 Battery Replacement, Disconnecting the Battery Cable: step 7, image 1 of 1
  8. Dell Alienware 14 Battery Replacement, Remove the Screws: step 8, image 1 of 1
    • Remove the screws that secure the battery to the computer base.
  9. Dell Alienware 14 Battery Replacement, Using the Battery Cable: step 9, image 1 of 1
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Dell Alienware 14 Battery Replacement, Turn the Computer Over: step 10, image 1 of 1
    • Turn the computer over and open the display as far as possible.
  11. Dell Alienware 14 Battery Replacement, The Power Button: step 11, image 1 of 1
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Dell Alienware 14 Battery Replacement, Align the Tabs: step 13, image 1 of 1
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Dell Alienware 14 Battery Replacement, Align the Screw Holes: step 14, image 1 of 1
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Dell Alienware 14 Battery Replacement, Replace the Screws: step 15, image 1 of 1
    • Replace the screws that secure the battery to the computer base.
  15. Dell Alienware 14 Battery Replacement, Connect the Battery Cable: step 16, image 1 of 1
    • Connect the battery cable to the system-board connector.
3 other people completed this guide.
Terrence15
79,930 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
44 Members
1,997 Guides authored
1 Guide Comment
I took my battery out and lost it. I didn't record the part number. Does anybody around here happen to have it handy?
ignacio - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 49
All Time: 2,361
