Dell Alienware M11x R3 Wi-Fi Card Replacement
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: step 1, image 1 of 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: step 1, image 2 of 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: step 1, image 3 of 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: step 2, image 1 of 2 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: step 2, image 2 of 2
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: step 3, image 1 of 1
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: step 4, image 1 of 2 Dell Alienware M11x R3 Wi-Fi Card Replacement: step 4, image 2 of 2
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
Richard Maurice
534 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 695
