Dell Alienware M17x R3 Hard Drive Replacement
  1. Dell Alienware M17x R3 Hard Drive Replacement, Loosen the Captive Screws: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
  2. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive: step 2, image 1 of 1
    • Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
  3. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Alienware M17x R3 Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Dell Alienware M17x R3 Hard Drive Replacement, Lifting the Hard-Drive: step 5, image 1 of 1
    • Lift the hard-drive off the hard-drive bracket.
  6. Dell Alienware M17x R3 Hard Drive Replacement, Remove the Interposer: step 6, image 1 of 1
    • Remove the interposer from the hard drive.
  7. Dell Alienware M17x R3 Hard Drive Replacement, Connecting the Interposer: step 7, image 1 of 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Alienware M17x R3 Hard Drive Replacement, Placing the Hard Drive: step 8, image 1 of 2 Dell Alienware M17x R3 Hard Drive Replacement, Placing the Hard Drive: step 8, image 2 of 2
    • Place the hard drive in the hard-drive bracket.
  9. Dell Alienware M17x R3 Hard Drive Replacement, Replace the Screws: step 9, image 1 of 1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  10. Dell Alienware M17x R3 Hard Drive Replacement, Align the Connector: step 10, image 1 of 1
    • Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
  11. Dell Alienware M17x R3 Hard Drive Replacement, Tighten the Screws: step 11, image 1 of 1
    • Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Terrence15
79,309 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,984 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 10
All Time: 1,267
