Dell Axim X30 Button Replacement
  1. Dell Axim X30 Button Replacement, Buttons: step 1, image 1 of 2 Dell Axim X30 Button Replacement, Buttons: step 1, image 2 of 2
    • Remove the four rubber feet with your fingers.
  2. Dell Axim X30 Button Replacement: step 2, image 1 of 2 Dell Axim X30 Button Replacement: step 2, image 2 of 2
    • Insert the nylon spudger into the battery cover release slot to remove the battery from the device.
  3. Dell Axim X30 Button Replacement: step 3, image 1 of 1
    • Remove four 12.7mm JIS #0 screws.
  4. Dell Axim X30 Button Replacement: step 4, image 1 of 1
    • Remove the back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel will pop off easily.
  5. Dell Axim X30 Button Replacement: step 5, image 1 of 3 Dell Axim X30 Button Replacement: step 5, image 2 of 3 Dell Axim X30 Button Replacement: step 5, image 3 of 3
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Dell Axim X30 Button Replacement: step 6, image 1 of 2 Dell Axim X30 Button Replacement: step 6, image 2 of 2
    • Remove three 12.7mm JIS #0 screws.
  7. Dell Axim X30 Button Replacement: step 7, image 1 of 1
    • Carefully remove motherboard.
  8. Dell Axim X30 Button Replacement: step 8, image 1 of 1
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Dell Axim X30 Button Replacement: step 9, image 1 of 2 Dell Axim X30 Button Replacement: step 9, image 2 of 2
    • Remove black plastic board.
  10. Dell Axim X30 Button Replacement: step 10, image 1 of 2 Dell Axim X30 Button Replacement: step 10, image 2 of 2
    • Remove grey and green membrane buttons.
Jonathan Gulley
187 Reputation
1 Guide authored
IUPUI, Team S2-G5, Harley Spring 2018 Member of IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 721
