Dell Chromebook 11 CB1C13 Battery Replacement
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: step 1, image 1 of 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: step 1, image 2 of 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: step 1, image 3 of 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: step 2, image 1 of 2 Dell Chromebook 11 CB1C13 Battery Replacement: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: step 3, image 1 of 2 Dell Chromebook 11 CB1C13 Battery Replacement: step 3, image 2 of 2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
To replace your Dell Chromebook 11 battery, follow these instructions in order.
2 other people completed this guide.
Jerry Geffrard
334 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 31
All Time: 1,430
