Dell Chromebook 11 CB1C13 Fan Replacement
  1. Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: step 1, image 1 of 3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: step 1, image 2 of 3 Dell Chromebook 11 CB1C13 Fan Replacement, Back Panel: step 1, image 3 of 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8 mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Fan Replacement, Fan: step 2, image 1 of 3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: step 2, image 2 of 3 Dell Chromebook 11 CB1C13 Fan Replacement, Fan: step 2, image 3 of 3
    • Locate the two wires that connect the fan to the device. One black, and one white.
    • Move these wires off of the fan by gently pulling on them.
    • Locate the two 8mm Philips #0 screws that connect the fan to the device.
    • Remove these screws using a Philips #0 screwdriver.
  3. Dell Chromebook 11 CB1C13 Fan Replacement: step 3, image 1 of 3 Dell Chromebook 11 CB1C13 Fan Replacement: step 3, image 2 of 3 Dell Chromebook 11 CB1C13 Fan Replacement: step 3, image 3 of 3
    • The fan is connected by a 5 pin port. Remove this by gently prying out the fan's port using your fingers or a plastic prying tool.
    • The pin port can be very delicate. Any major bending or twisting can cause permanent damage to the port, and may leave it unable to work.
Bryan Allen
272 Reputation
2 Guides authored
One Comment
Ram?
Can i change the ram?
flip - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,056
