Dell Chromebook 11-3120 Battery Replacement
  1. Dell Chromebook 11-3120 Battery Replacement, Remove screws: step 1, image 1 of 1
    • Flip the device over so the bottom is facing up
    • Remove the 7 visible Philips screws from the device's bottom cover
  2. Dell Chromebook 11-3120 Battery Replacement: step 2, image 1 of 2 Dell Chromebook 11-3120 Battery Replacement: step 2, image 2 of 2
    • Insert a thin prying tool into the front (facing the user) corner between the rubber bumper and the plastic case to pop several latches.
    • Starting from the partially-opened corner, pull the case away from the device in a hinging motion. I rotated the computer so that the opened corner faced me in the image.
  3. Dell Chromebook 11-3120 Battery Replacement, Unplug battery connector: step 3, image 1 of 1
    • Unplug the battery connector from the motherboard
  4. Dell Chromebook 11-3120 Battery Replacement, Remove screws: step 4, image 1 of 1
    • Remove the two silver screws that hold the battery to the case
    • Lift the battery straight out of the case and place it in a safe, static-free place
May D
2,659 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 439
