Dell Chromebook 13-7310 Cooling Fan Replacement
  1. Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Cooling Fan Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Dell Chromebook 13-7310 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Using the #1 Philips screwdriver, remove the two, 2mm screws securing the fan assembly.
  4. Dell Chromebook 13-7310 Cooling Fan Replacement: step 4, image 1 of 2 Dell Chromebook 13-7310 Cooling Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using your fingernails, pull the cooling fan cables loose from the motherboard.
    • We have the tweezers pictured to allow for a clear view of components. DO NOT use the tweezers to remove the cables, they could be damaged in the process.
    • Finally, lift the fan assembly away from the computer.
Congratulations! You have successfully removed the cooling fan of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 521
