Dell Chromebook 13-7310 IO Board Replacement
  1. Dell Chromebook 13-7310 IO Board Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 13-7310 IO Board Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 IO Board Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 IO Board Replacement, Battery: step 3, image 1 of 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 IO Board Replacement: step 4, image 1 of 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 IO Board Replacement: step 5, image 1 of 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 IO Board Replacement, IO Board: step 6, image 1 of 1
    • Remove the single 2mm screw securing the IO board to the laptop.
  7. Dell Chromebook 13-7310 IO Board Replacement: step 7, image 1 of 1
    • Pull up on the connector to release the IO board cable from the motherboard.
    • It may be easier to pull from the blue tab.
  8. Dell Chromebook 13-7310 IO Board Replacement: step 8, image 1 of 1
    • Remove the IO board.
Damon
181 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 350
