Dell Chromebook 13-7310 Motherboard Replacement
  1. Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 13-7310 Motherboard Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Motherboard Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Motherboard Replacement, Battery: step 3, image 1 of 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Motherboard Replacement: step 4, image 1 of 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Motherboard Replacement: step 5, image 1 of 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Motherboard Replacement, Network Card: step 6, image 1 of 2 Dell Chromebook 13-7310 Motherboard Replacement, Network Card: step 6, image 2 of 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Motherboard Replacement: step 7, image 1 of 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Motherboard Replacement: step 8, image 1 of 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
  9. Dell Chromebook 13-7310 Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Gently pull to unplug fan connector.
  10. Dell Chromebook 13-7310 Motherboard Replacement: step 10, image 1 of 2 Dell Chromebook 13-7310 Motherboard Replacement: step 10, image 2 of 2
    • Remove 4 screws securing heat sink.
  11. Dell Chromebook 13-7310 Motherboard Replacement: step 11, image 1 of 1
    • Lift away heat sink.
  12. Dell Chromebook 13-7310 Motherboard Replacement: step 12, image 1 of 1
    • Remove the eight 2mm screws securing the motherboard in place.
  13. Dell Chromebook 13-7310 Motherboard Replacement: step 13, image 1 of 1
    • Release cable for the LED charging indicator by pulling up on connector.
  14. Dell Chromebook 13-7310 Motherboard Replacement: step 14, image 1 of 1
    • Gently remove the cable.
  15. Dell Chromebook 13-7310 Motherboard Replacement: step 15, image 1 of 1
    • Pull up on connector tab to release IO board cable.
  16. Dell Chromebook 13-7310 Motherboard Replacement: step 16, image 1 of 2 Dell Chromebook 13-7310 Motherboard Replacement: step 16, image 2 of 2
    • Pull up on connector tab to release touchpad cable.
  17. Dell Chromebook 13-7310 Motherboard Replacement: step 17, image 1 of 1
    • Release the keyboard backlight cable.
  18. Dell Chromebook 13-7310 Motherboard Replacement: step 18, image 1 of 2 Dell Chromebook 13-7310 Motherboard Replacement: step 18, image 2 of 2
    • Release the keyboard cable.
    • If taped to the motherboard, gently peel it off.
  19. Dell Chromebook 13-7310 Motherboard Replacement: step 19, image 1 of 1
    • Release eDP cable.
  20. Dell Chromebook 13-7310 Motherboard Replacement: step 20, image 1 of 1
    • Release dc-in cable.
  21. Dell Chromebook 13-7310 Motherboard Replacement: step 21, image 1 of 1
    • Gently lift up the motherboard to remove it.
Brett Raymond
469 Reputation
3 Guides authored
One Comment
Is it possible to swap the non-touch matte display and the glossy touchscreen on two Dell Chromebook 13 7310?
Jeremy Ryan Terrence - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 929
