Dell Chromebook 13-7310 Network Card Replacement
  1. Dell Chromebook 13-7310 Network Card Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 13-7310 Network Card Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven 3mm Phillips #1 screws.
  2. Dell Chromebook 13-7310 Network Card Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to gently remove the back panel.
    • It can be easier to pry open near a corner.
  3. Dell Chromebook 13-7310 Network Card Replacement, Battery: step 3, image 1 of 1
    • Use your fingers to remove the connecting cable to the battery unit. Firmly grab the cord closest to the motherboard connection and pull straight back.
  4. Dell Chromebook 13-7310 Network Card Replacement: step 4, image 1 of 1
    • Remove the four 2mm screws on the sides of the battery.
  5. Dell Chromebook 13-7310 Network Card Replacement: step 5, image 1 of 1
    • To remove the battery, lift up on one side to get your fingers underneath and lift away.
  6. Dell Chromebook 13-7310 Network Card Replacement, Network Card: step 6, image 1 of 2 Dell Chromebook 13-7310 Network Card Replacement, Network Card: step 6, image 2 of 2
    • Use #1 Phillips screwdriver to remove the 1mm screw in the network card.
  7. Dell Chromebook 13-7310 Network Card Replacement: step 7, image 1 of 1
    • Disconnect the network card from motherboard socket.
  8. Dell Chromebook 13-7310 Network Card Replacement: step 8, image 1 of 1
    • Disconnect 2 cable connectors from network card.
    • If the cables are stuck, continue to gently wiggle them until they disconnect.
Brett Raymond
469 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 575
