Dell Chromebook 13-7310 Web Camera Replacement
  1. Dell Chromebook 13-7310 Web Camera Replacement, Web Camera: step 1, image 1 of 3 Dell Chromebook 13-7310 Web Camera Replacement, Web Camera: step 1, image 2 of 3 Dell Chromebook 13-7310 Web Camera Replacement, Web Camera: step 1, image 3 of 3
    • To remove the screen, start by using the black nylon spudger to pry off the plastic hinge cover. This allows easy removal of the screen cover.
    • Using the same spudger and your finger nails, gently pry the outer casing around the screen itself. Once it is 1/3 to 1/2 of the way removed, gently pull the rest free by hand.
    • CAUTION There will be popping/snapping sounds when removing. This is normal, just be careful not the crack any plastic or the cover may not reinstall properly.
    • Once the clips are undone, remove the cover and you are ready for the next step!
  2. Dell Chromebook 13-7310 Web Camera Replacement: step 2, image 1 of 2 Dell Chromebook 13-7310 Web Camera Replacement: step 2, image 2 of 2
    • Now that the camera is exposed, disconnect the wire by hand to untether the camera unit from the motherboard.
    • To disconnect, pull to the straight back from the camera connection point.
  3. Dell Chromebook 13-7310 Web Camera Replacement: step 3, image 1 of 2 Dell Chromebook 13-7310 Web Camera Replacement: step 3, image 2 of 2
    • Once you have disconnected the camera, use the small nylon pry bar to dislodge the camera assembly from the computer housing.
    • CAUTION The camera assembly is held very securely to an thin alloy backing plate. Pry slowly and gently as to not damage the backing plate when removing.
    • After the camera assembly is free from the backing plate, remove it from the housing bay hand.
Congratulations! You have successfully removed the web camera of your Dell Chromebook 13-7310. To reassemble your device, follow these instructions in reverse order.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 557
