Dell Chromebook 3100 2-in-1 Display Replacement
  1. Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement, Back Cover: step 1, image 2 of 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Display Replacement: step 2, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement: step 2, image 2 of 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Display Replacement, Battery: step 3, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Display Replacement: step 4, image 1 of 3 Dell Chromebook 3100 2-in-1 Display Replacement: step 4, image 2 of 3 Dell Chromebook 3100 2-in-1 Display Replacement: step 4, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Display Replacement: step 5, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement: step 5, image 2 of 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Display Replacement, Display: step 6, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement, Display: step 6, image 2 of 2
    • Remove the single 3 mm screw that secures the WLAN bracket to the system board using a Phillips #1 screwdriver.
    • Lift the WLAN bracket from the system board.
    • After lifting the bracket, carefully unplug the two coaxial cables.
  7. Dell Chromebook 3100 2-in-1 Display Replacement: step 7, image 1 of 1
    • Remove the single 4 mm screw that secures the eDP bracket to the motherboard using a Phillips #1 screwdriver.
    • Remove the eDP bracket.
  8. Dell Chromebook 3100 2-in-1 Display Replacement: step 8, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement: step 8, image 2 of 2
    • Disconnect the display cable from the motherboard by using a plastic opening pick.
  9. Dell Chromebook 3100 2-in-1 Display Replacement: step 9, image 1 of 1
    • Open the system to 180 degrees and place the computer on a flat surface, with the display hinges facing up.
  10. Dell Chromebook 3100 2-in-1 Display Replacement: step 10, image 1 of 3 Dell Chromebook 3100 2-in-1 Display Replacement: step 10, image 2 of 3 Dell Chromebook 3100 2-in-1 Display Replacement: step 10, image 3 of 3
    • Remove the three (on both hinges) 5 mm display hinge bracket screws that secure the display assembly to the system using a Phillips #1 screwdriver.
  11. Dell Chromebook 3100 2-in-1 Display Replacement: step 11, image 1 of 1
    • Remove the display assembly from the system.
  12. Dell Chromebook 3100 2-in-1 Display Replacement: step 12, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement: step 12, image 2 of 2
    • Use the opening tool to open the display panel starting from the pry points located above the left and right hinges.
    • Work your way around, through the left and right side of the panel, and carefully flip the display panel over.
  13. Dell Chromebook 3100 2-in-1 Display Replacement: step 13, image 1 of 2 Dell Chromebook 3100 2-in-1 Display Replacement: step 13, image 2 of 2
    • Peel back the adhesive tape securing the display cable on the back of the display panel and separate the display.
M Ali
301 Reputation
2 Guides authored
Gateway, Team 1-1, Pee Fall 2021 Member of Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,659
