Dell Chromebook 3100 2-in-1 Speaker Replacement
  1. Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: step 1, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Back Cover: step 1, image 2 of 2
    • Using a Phillips #1 screwdriver, remove all nine of the 5 mm screws from the back cover.
  2. Dell Chromebook 3100 2-in-1 Speaker Replacement: step 2, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: step 2, image 2 of 2
    • Use the opening tool to pry the back cover off of the device.
  3. Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: step 3, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Chromebook 3100 2-in-1 Speaker Replacement: step 4, image 1 of 3 Dell Chromebook 3100 2-in-1 Speaker Replacement: step 4, image 2 of 3 Dell Chromebook 3100 2-in-1 Speaker Replacement: step 4, image 3 of 3
    • Using a Phillips #1 screwdriver, remove the three 4 mm screws that secure the battery.
    • Remove the adhesive tape that secures the battery in place.
  5. Dell Chromebook 3100 2-in-1 Speaker Replacement: step 5, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: step 5, image 2 of 2
    • Carefully remove the battery from the device.
  6. Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: step 6, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement, Speaker: step 6, image 2 of 2
    • Remove adhesive tape that secures the speaker cable.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Chromebook 3100 2-in-1 Speaker Replacement: step 7, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: step 7, image 2 of 2
    • Remove the speaker cable from the retention clips.
  8. Dell Chromebook 3100 2-in-1 Speaker Replacement: step 8, image 1 of 2 Dell Chromebook 3100 2-in-1 Speaker Replacement: step 8, image 2 of 2
    • Lift and remove the speakers from the device.
M Ali
301 Reputation
2 Guides authored
Gateway, Team 1-1, Pee Fall 2021 Member of Gateway, Team 1-1, Pee Fall 2021
GCC-PEE-F21S1G1
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 276
