Dell Chromebook 3110 Battery Replacement
  1. Dell Chromebook 3110 Battery Replacement, Battery: step 1, image 1 of 1
    • Set the laptop upside down on a clean work space.
  2. Dell Chromebook 3110 Battery Replacement: step 2, image 1 of 1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
  3. Dell Chromebook 3110 Battery Replacement: step 3, image 1 of 1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
  4. Dell Chromebook 3110 Battery Replacement: step 4, image 1 of 1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
  5. Dell Chromebook 3110 Battery Replacement: step 5, image 1 of 1
    • Carefully lift the battery out of the laptop.
Anna K Tomko
136 Reputation
1 Guide authored
Marist, Team 1-6, Chaterdon Spring 2023 Member of Marist, Team 1-6, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G6
2 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 290
