Introduction
If your battery is dead or just isn't properly holding a charge, follow this guide.
Using the metal spudger, carefully slide it under the black rubber bottom to remove it.
Using a Phillips J000 head screw driver, unscrew the 4mm screws placed on the outer corners of the metal plate.
Again, take the metal spudger, placing it under the metal plate to take it off.
