Dell Dimension 4600 RAM Replacement
  1. Dell Dimension 4600 RAM Replacement, Side Panel: step 1, image 1 of 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 RAM Replacement: step 2, image 1 of 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 RAM Replacement: step 3, image 1 of 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 RAM Replacement, RAM: step 4, image 1 of 1
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Locate the RAM modules on the motherboard.
  5. Dell Dimension 4600 RAM Replacement: step 5, image 1 of 2 Dell Dimension 4600 RAM Replacement: step 5, image 2 of 2
    • Locate the white or black tabs holding the RAM module in place.
    • Place your index finger on the tab and firmly press down. The tab should release and the RAM module should be slightly raised.
    • Repeat this for the tab on the other side of the RAM module.
    • Repeat this step for each RAM module.
  6. Dell Dimension 4600 RAM Replacement: step 6, image 1 of 2 Dell Dimension 4600 RAM Replacement: step 6, image 2 of 2
    • Grasp the RAM module and firmly pull upwards until it is released from its slot.
13 other people completed this guide.
Daniel Crawford
1,021 Reputation
2 Guides authored
Cal Poly, Team 6-10, Regan Fall 2011 Member of Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Members
11 Guides authored
1 Guide Comment
Would be great if the DIMM slots were explained (numbering) as to which are populated for dual channel, etc.
MJfromMD - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 10,496
