Dell Dimension 4600 Sound Card Replacement
  1. Dell Dimension 4600 Sound Card Replacement, Side Panel: step 1, image 1 of 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Sound Card Replacement: step 2, image 1 of 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Sound Card Replacement: step 3, image 1 of 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Sound Card Replacement, Sound Card: step 4, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Lay the computer flat on its side so that you are looking down on all of the components.
    • Very important at this point you connect your antistatic wrist strap to the chassis because the computer is no longer connected to ground at the power source. There is potential for static discharge which could destroy components.
  5. Dell Dimension 4600 Sound Card Replacement: step 5, image 1 of 1
    • Locate the Sound Card and the screw attached to the Sound Card as shown in the picture.
  6. Dell Dimension 4600 Sound Card Replacement: step 6, image 1 of 1
    • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
  7. Dell Dimension 4600 Sound Card Replacement: step 7, image 1 of 3 Dell Dimension 4600 Sound Card Replacement: step 7, image 2 of 3 Dell Dimension 4600 Sound Card Replacement: step 7, image 3 of 3
    • Locate and remove the white connector on the sound card by pulling on the black cable.
  8. Dell Dimension 4600 Sound Card Replacement: step 8, image 1 of 2 Dell Dimension 4600 Sound Card Replacement: step 8, image 2 of 2
    • Grasp the Sound Card and pull it up and out of it's slot.
6 other people completed this guide.
Arvind
395 Reputation
2 Guides authored
Cal Poly, Team 6-10, Regan Fall 2011 Member of Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 5,291
