Dell E193FPc Interface Buttons Replacement
  1. Dell E193FPc Interface Buttons Replacement, Stand: step 1, image 1 of 1
    • Lay the monitor screen-down so the back screws are exposed.
    • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
  2. Dell E193FPc Interface Buttons Replacement: step 2, image 1 of 1
    • Gently lift and pull away the stand at a slight angle away from the monitor.
  3. Dell E193FPc Interface Buttons Replacement, Display Bezel: step 3, image 1 of 2 Dell E193FPc Interface Buttons Replacement, Display Bezel: step 3, image 2 of 2
    • Locate the two holes on the bottom of the monitor.
    • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
    • This task is much easier if two people pry simultaneously at each hole.
    • Continue prying along the entire edge of the monitor.
  4. Dell E193FPc Interface Buttons Replacement: step 4, image 1 of 2 Dell E193FPc Interface Buttons Replacement: step 4, image 2 of 2
    • When finished prying, the plastic will partially fall away from the rest of the monitor.
    • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
    • While holding the frames together, carefully flip the monitor over so it faces screen down.
    • Gently lift and remove remove the rear case from the monitor.
  5. Dell E193FPc Interface Buttons Replacement: step 5, image 1 of 3 Dell E193FPc Interface Buttons Replacement: step 5, image 2 of 3 Dell E193FPc Interface Buttons Replacement: step 5, image 3 of 3
    • Locate the green interface button board.
    • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
    • Lift the monitor interior away from the front cover.
  6. Dell E193FPc Interface Buttons Replacement, Interface Buttons: step 6, image 1 of 1
    • Behind the front panel of the plastic cover lies the button strip.
    • Remove the buttons by gently pulling up on the strip.
    • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
Charley Grove
98 Reputation
1 Guide authored
Cal Poly, Team 5-36, Amido Fall 2011 Member of Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Members
12 Guides authored
1 Guide Comment
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,374
