Dell G15-5510 Gaming Back Cover Replacement
  1. Dell G15-5510 Gaming Back Cover Replacement, Unfasten the back cover: step 1, image 1 of 2 Dell G15-5510 Gaming Back Cover Replacement, Unfasten the back cover: step 1, image 2 of 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four screws securing the back cover.
    • Two 8 mm screws
    • Two 5.8 mm screws
    • Loosen the four captive screws.
  2. Dell G15-5510 Gaming Back Cover Replacement, Unclip the front corners: step 2, image 1 of 2 Dell G15-5510 Gaming Back Cover Replacement, Unclip the front corners: step 2, image 2 of 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry upward to release clips holding the cover in place.
    • Listen for a loud click to indicate a clip being released.
  3. Dell G15-5510 Gaming Back Cover Replacement: step 3, image 1 of 2 Dell G15-5510 Gaming Back Cover Replacement: step 3, image 2 of 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5510 Gaming Back Cover Replacement, Remove the back cover: step 4, image 1 of 3 Dell G15-5510 Gaming Back Cover Replacement, Remove the back cover: step 4, image 2 of 3 Dell G15-5510 Gaming Back Cover Replacement, Remove the back cover: step 4, image 3 of 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
Clay Eickemeyer
69,526 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 109
All Time: 1,640
