Dell G15-5511 Gaming Right SSD (Slot 2) Replacement
  1. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: step 1, image 1 of 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: step 1, image 2 of 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: step 2, image 1 of 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: step 2, image 2 of 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: step 3, image 1 of 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: step 3, image 2 of 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: step 4, image 1 of 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: step 4, image 2 of 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: step 4, image 3 of 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: step 5, image 1 of 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: step 5, image 2 of 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: step 6, image 1 of 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: step 6, image 2 of 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: step 6, image 3 of 3
    • The right SSD slot has two locations install the standoff bracket—one for the short M.2 2230 SSD, and one for the longer M.2 2280 SSD.
    • Use the flat end of a spudger to press the the bracket into the slot. The wings of the standoff will clip underneath the tabs of the slot.
    • Slide in the standoff edge of the bracket first.
  7. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: step 7, image 1 of 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: step 7, image 2 of 2
    • Grip your 80 mm-long (M.2 2280) SSD by the corners near the screw indent.
    • Slide the SSD into the socket.
  8. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: step 8, image 1 of 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: step 8, image 2 of 2
    • Use your Phillips #0 screwdriver to fasten the 4.2 mm-long screw to the SSD standoff.
To reassemble your Dell G15, follow these instructions in reverse order.
For general information on how to install a SSD, refer to this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
Clay Eickemeyer
69,526 Reputation
453 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 9
Past 7 Days: 35
Past 30 Days: 138
All Time: 3,568
