Dell G7 15-7588 RAM Replacement
  1. Dell G7 15-7588 RAM Replacement, RAM: step 1, image 1 of 2 Dell G7 15-7588 RAM Replacement, RAM: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to unscrew the 2 mm screw that secures the bottom cover.
    • This screw can not be fully removed from the bottom cover. It will only lift the back cover up the laptop up and allow it to be removed.
    • This will raise the bottom cover of the laptop centered around the screw, providing a easy point to remove the laptop back from later.
  2. Dell G7 15-7588 RAM Replacement: step 2, image 1 of 1
    • Remove the bottom cover from the laptop by pulling back the cover.
    • It is recommended to start from where the screw near the top of the laptop lifts the cover.
  3. Dell G7 15-7588 RAM Replacement: step 3, image 1 of 3 Dell G7 15-7588 RAM Replacement: step 3, image 2 of 3 Dell G7 15-7588 RAM Replacement: step 3, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the three 2.5 mm screws from the battery brackets.
  4. Dell G7 15-7588 RAM Replacement: step 4, image 1 of 1
    • Grab both sides of the battery connector.
    • Pull the battery connector straight back to disconnect it from the laptop.
    • This will completely disconnect the batter from the laptop.
  5. Dell G7 15-7588 RAM Replacement: step 5, image 1 of 2 Dell G7 15-7588 RAM Replacement: step 5, image 2 of 2
    • Push the sides of the metal retention clips outward.
    • This will release the RAM from its locked state and cause it to rise upward, allowing for removal.
    • The same method is used for both pieces of RAM.
  6. Dell G7 15-7588 RAM Replacement: step 6, image 1 of 2 Dell G7 15-7588 RAM Replacement: step 6, image 2 of 2
    • Remove the RAM from the laptop by pulling it up from the slot.
Ryan Peschke
141 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 41
All Time: 610
