Dell Inspiron 11 3179 Display Assembly Replacement
  1. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Screw: step 1, image 1 of 1
  2. Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Cable: step 2, image 1 of 1
    • Lift the display-cable bracket off the system board.
  3. Dell Inspiron 11 3179 Display Assembly Replacement, Peeling the Tape: step 3, image 1 of 1
    • Peel off the tape to access the display cable.
  4. Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Display Cable: step 4, image 1 of 2 Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Display Cable: step 4, image 2 of 2
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Sensor-Board Cable: step 5, image 1 of 2 Dell Inspiron 11 3179 Display Assembly Replacement, Disconnecting the Sensor-Board Cable: step 5, image 2 of 2
    • Open the latch and disconnect the sensor-board cable from the I/O board.
  6. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Antenna Cable: step 6, image 1 of 2 Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Antenna Cable: step 6, image 2 of 2
    • Remove the antenna cable from the routing guide on the right speaker.
  7. Dell Inspiron 11 3179 Display Assembly Replacement, Open the Latch: step 7, image 1 of 1
    • Open the latch and disconnect the I/O-board cable from the system board.
  8. Dell Inspiron 11 3179 Display Assembly Replacement, Peeling the Tapes: step 8, image 1 of 1
    • Peel the tapes off the display hinges.
  9. Dell Inspiron 11 3179 Display Assembly Replacement, Opening the Display: step 9, image 1 of 1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  10. Dell Inspiron 11 3179 Display Assembly Replacement, Remove the Screws: step 10, image 1 of 1
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest and keyboard assembly.
  11. Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Assembly: step 11, image 1 of 2 Dell Inspiron 11 3179 Display Assembly Replacement, Lifting the Display Assembly: step 11, image 2 of 2
    • Lift the display assembly off the palm-rest and keyboard assembly.
  12. Dell Inspiron 11 3179 Display Assembly Replacement, Placing the Display Assembly: step 12, image 1 of 1
    • Place the NEW display assembly on the palm-rest and keyboard assembly.
  13. Dell Inspiron 11 3179 Display Assembly Replacement, Align the Screw Holes: step 13, image 1 of 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest and keyboard assembly.
  14. Dell Inspiron 11 3179 Display Assembly Replacement, Replace the Screws: step 14, image 1 of 1
    • Replace the screws that secure the display assembly to the palm-rest and keyboard assembly.
  15. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the I/O Board Cable: step 15, image 1 of 1
    • Turn the computer over and close the display.
    • Slide the I/O-board cable into its slot on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 11 3179 Display Assembly Replacement, Routing the Antenna Cable: step 16, image 1 of 1
    • Route the antenna cable through its routing on the right speaker.
  17. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the Sensor-Board Cable: step 17, image 1 of 1
    • Slide the sensor-board cable into its slot on the I/O board and press down the latch to secure the cable.
  18. Dell Inspiron 11 3179 Display Assembly Replacement, Sliding the Display Cable: step 18, image 1 of 1
    • Slide the display cable into its slot on the system board and press down the latch to secure the cable.
  19. Dell Inspiron 11 3179 Display Assembly Replacement, Adhering the Tape: step 19, image 1 of 1
    • Adhere the tape on the display cable.
  20. Dell Inspiron 11 3179 Display Assembly Replacement, Align the Screw Hole: step 20, image 1 of 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  21. Dell Inspiron 11 3179 Display Assembly Replacement, Replace the Screw: step 21, image 1 of 1
    • Replace the screw that secures the display-cable bracket to the system board.
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 271
