Dell Inspiron 11 i3147 Camera Replacement
  1. Dell Inspiron 11 i3147 Camera Replacement, Camera: step 1, image 1 of 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Camera Replacement: step 2, image 1 of 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Camera Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Camera Replacement: step 4, image 1 of 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Camera Replacement: step 5, image 1 of 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Camera Replacement: step 6, image 1 of 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Camera Replacement: step 7, image 1 of 1
    • Disconnect antenna cables.
  8. Dell Inspiron 11 i3147 Camera Replacement: step 8, image 1 of 1
    • Remove 2 4mm PH0 screws that connect display cable bracket to the system board.
    • Lift display cable bracket off the system board.
  9. Dell Inspiron 11 i3147 Camera Replacement: step 9, image 1 of 1
    • Use the pull tab to disconnect the display cable from the system board.
  10. Dell Inspiron 11 i3147 Camera Replacement: step 10, image 1 of 1
    • Pull the windows button board cable from the system board.
  11. Dell Inspiron 11 i3147 Camera Replacement: step 11, image 1 of 1
    • Remove the 2 5.6mm PH0 screws.
  12. Dell Inspiron 11 i3147 Camera Replacement: step 12, image 1 of 1
    • Separate the screen and body of the computer.
  13. Dell Inspiron 11 i3147 Camera Replacement: step 13, image 1 of 2 Dell Inspiron 11 i3147 Camera Replacement: step 13, image 2 of 2
    • Use a plastic opening tool to take the display panel assembly off the display back cover and antenna assembly. Start from the top.
    • Place display panel face down on a flat surface
  14. Dell Inspiron 11 i3147 Camera Replacement: step 15, image 1 of 1
    • Use a plastic opening tool to take the camera module off the display.
Muhammad Erchid
1,069 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2018 Member of USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 223
