Dell Inspiron 11 i3147 Hard Drive Replacement
  1. Dell Inspiron 11 i3147 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Hard Drive Replacement: step 2, image 1 of 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Hard Drive Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Hard Drive Replacement: step 4, image 1 of 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Hard Drive Replacement: step 5, image 1 of 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Hard Drive Replacement: step 6, image 1 of 1
    • Lift the battery from the computer.
  7. Dell Inspiron 11 i3147 Hard Drive Replacement: step 7, image 1 of 1
    • Peel off the adhesive strap from the hard drive.
  8. Dell Inspiron 11 i3147 Hard Drive Replacement: step 8, image 1 of 1
    • Use a PH0 screwdriver to remove the 2 3.9 mm PH0 screws on the hard drive.
  9. Dell Inspiron 11 i3147 Hard Drive Replacement: step 9, image 1 of 1
    • Lift the hard drive to free it from the laptop.
  10. Dell Inspiron 11 i3147 Hard Drive Replacement: step 10, image 1 of 1
    • Remove interposer from the hard drive.
  11. Dell Inspiron 11 i3147 Hard Drive Replacement: step 11, image 1 of 1
    • Use pull tab to remove hard drive cable from motherboard.
Muhammad Erchid
1,069 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2018 Member of USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 271
