Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement
  1. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement, Power Buttons and Volume-Buttons Board: step 1, image 1 of 1
    • Close the computer and turn it over so that the bottom of the computer is facing up.
  2. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: step 2, image 1 of 1
    • Remove the nine 7.6mm PH0 screws on the back cover.
  3. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to remove the cover from the back of the computer.
  4. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: step 4, image 1 of 1
    • Remove the three small 4.7mm PH0 screws that secure the battery.
  5. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: step 5, image 1 of 1
    • Move the hard drive cable away from the battery.
    • You want to make enough clearance to remove the battery without it catching on the hard drive cable.
  6. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: step 6, image 1 of 1
    • Lift the battery up and toward yourself to remove it, revealing the back of the keyboard underneath.
  7. Dell Inspiron 11 i3147 Power Buttons and Volume-Buttons Board Replacement: step 7, image 1 of 1
    • Disconnect the cable for the power and volume buttons from the motherboard.
    • You may need to use a spudger to remove the cable from the routing guides by the speaker.
Muhammad Erchid
1,069 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Leahy Fall 2018 Member of USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 386
