Dell Inspiron 11-3147 Hard Drive Replacement
  1. Dell Inspiron 11-3147 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Dell Inspiron 11-3147 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Hard Drive Replacement: step 2, image 1 of 1
    • Using the tab on the cables connector with your hand unplug the Hard Drive connection cable and remove it from the cable track on the battery.
  3. Dell Inspiron 11-3147 Hard Drive Replacement: step 3, image 1 of 3 Dell Inspiron 11-3147 Hard Drive Replacement: step 3, image 2 of 3 Dell Inspiron 11-3147 Hard Drive Replacement: step 3, image 3 of 3
    • Pull back the sticker covering the first screw on the hard drive chaises.
    • Useing a Philips Head #0 screwdriver remove the three screws holding the drive in place.
  4. Dell Inspiron 11-3147 Hard Drive Replacement: step 4, image 1 of 1
    • Lift the hard drive from the left side as depicted and remove.
  5. Dell Inspiron 11-3147 Hard Drive Replacement: step 5, image 1 of 1
    • Unplug the adapter cable from the drive. No tool is required for this step.
  6. Dell Inspiron 11-3147 Hard Drive Replacement: step 6, image 1 of 3 Dell Inspiron 11-3147 Hard Drive Replacement: step 6, image 2 of 3 Dell Inspiron 11-3147 Hard Drive Replacement: step 6, image 3 of 3
    • Using a Philips Head #1 Screwdriver remove the four screws holding the hard drive to the chassis.
    • Remove the drive from the chassis. Care that the drive does not fall out once all the screwshave been removed.
4 other people completed this guide.
William Brum
755 Reputation
5 Guides authored
One Comment
I am a visual learner and with this guide, I had my hard drive changed and the backplate back on in less than 10 minutes. Thanks for the great guide.
Chris Hartfield - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 23
All Time: 5,516
