Dell Inspiron 11-3152 Screen Replacement
  1. Dell Inspiron 11-3152 Screen Replacement, Back Panel: step 1, image 1 of 2 Dell Inspiron 11-3152 Screen Replacement, Back Panel: step 1, image 2 of 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Screen Replacement: step 2, image 1 of 2 Dell Inspiron 11-3152 Screen Replacement: step 2, image 2 of 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Screen Replacement: step 3, image 1 of 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Screen Replacement, Battery: step 4, image 1 of 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Screen Replacement: step 5, image 1 of 2 Dell Inspiron 11-3152 Screen Replacement: step 5, image 2 of 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Screen Replacement: step 6, image 1 of 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Screen Replacement: step 7, image 1 of 1
    • Remove the battery from the computer system by gently lifting it from the side.
  8. Dell Inspiron 11-3152 Screen Replacement, Screen: step 8, image 1 of 1
    • Unscrew the brackets in the top right and top left of the laptop. Unscrew the two 1mm screw from both of the brackets on both sides with #0 phillips head.
  9. Dell Inspiron 11-3152 Screen Replacement: step 9, image 1 of 1
    • Disconnect the aerial cables from the wireless controller by pulling them away from the laptop.
  10. Dell Inspiron 11-3152 Screen Replacement: step 10, image 1 of 1
    • Push the brackets up on both sides with your hands or spudger.
  11. Dell Inspiron 11-3152 Screen Replacement: step 11, image 1 of 2 Dell Inspiron 11-3152 Screen Replacement: step 11, image 2 of 2
    • At this point you can pull the bottom half of the computer away from the screen.
    • The screen is now fully detached and ready to be replaced!
Matthew Duncan
481 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 525
