Dell Inspiron 11-3164 Speaker Assembly Replacement
  1. Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: step 1, image 1 of 2 Dell Inspiron 11-3164 Speaker Assembly Replacement, Speaker Assembly: step 1, image 2 of 2
    • Remove the eight 6mm back panel screws with your PH1 Phillips head screw driver bit.
    • Use your screw driver to remove the plastic cover in the center of the laptop.
    • Using a PH1 Phillips head screw driver bit remove the last 6mm screw.
  2. Dell Inspiron 11-3164 Speaker Assembly Replacement: step 2, image 1 of 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: step 2, image 2 of 2
    • Use your metal pry tool to pry around the laptop until the two pieces separate.
    • There will be a ribbon cable holding the two pieces together, be careful not to rip it out of it's socket.
    • Use your metal pry tool to release the connector.
  3. Dell Inspiron 11-3164 Speaker Assembly Replacement: step 3, image 1 of 2 Dell Inspiron 11-3164 Speaker Assembly Replacement: step 3, image 2 of 2
    • Remove the speaker plug from it's socket.
    • Lift the speaker assembly from the case.
Michael Kendziora
781 Reputation
5 Guides authored
USF Tampa, Team S6-G4, Eyestone Spring 2018 Member of USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 149
