Dell Inspiron 11-3168 Memory modules Replacement
  1. Dell Inspiron 11-3168 Memory modules Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 11-3168 Memory modules Replacement, Battery: step 1, image 2 of 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Memory modules Replacement: step 2, image 1 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 2, image 2 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 2, image 3 of 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Memory modules Replacement: step 3, image 1 of 2 Dell Inspiron 11-3168 Memory modules Replacement: step 3, image 2 of 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Memory modules Replacement: step 4, image 1 of 2 Dell Inspiron 11-3168 Memory modules Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Memory modules Replacement: step 5, image 1 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 5, image 2 of 3 Dell Inspiron 11-3168 Memory modules Replacement: step 5, image 3 of 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: step 6, image 1 of 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: step 6, image 2 of 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: step 6, image 3 of 3
    • Press down on the two latches on either side of the memory module.
    • Lift and remove the memory module.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 739
