Dell Inspiron 11-3168 Screen Replacement
  1. Dell Inspiron 11-3168 Screen Replacement, Battery: step 1, image 1 of 2 Dell Inspiron 11-3168 Screen Replacement, Battery: step 1, image 2 of 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Screen Replacement: step 2, image 1 of 3 Dell Inspiron 11-3168 Screen Replacement: step 2, image 2 of 3 Dell Inspiron 11-3168 Screen Replacement: step 2, image 3 of 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Screen Replacement: step 3, image 1 of 2 Dell Inspiron 11-3168 Screen Replacement: step 3, image 2 of 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Screen Replacement: step 4, image 1 of 2 Dell Inspiron 11-3168 Screen Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Screen Replacement: step 5, image 1 of 3 Dell Inspiron 11-3168 Screen Replacement: step 5, image 2 of 3 Dell Inspiron 11-3168 Screen Replacement: step 5, image 3 of 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Screen Replacement, Screen: step 6, image 1 of 3 Dell Inspiron 11-3168 Screen Replacement, Screen: step 6, image 2 of 3 Dell Inspiron 11-3168 Screen Replacement, Screen: step 6, image 3 of 3
    • Carefully flip the laptop over so that the top case is facing up.
    • Remove the top case of the laptop by gently prying along the seam with a plastic opening tool.
  7. Dell Inspiron 11-3168 Screen Replacement: step 7, image 1 of 3 Dell Inspiron 11-3168 Screen Replacement: step 7, image 2 of 3 Dell Inspiron 11-3168 Screen Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to grip the tape that is holding down the display cable clip.
    • Gently unpeel the tape. This will release the clip that locks over the display connector socket.
    • Once unclipped, remove the display cable from the socket.
  8. Dell Inspiron 11-3168 Screen Replacement: step 8, image 1 of 3 Dell Inspiron 11-3168 Screen Replacement: step 8, image 2 of 3 Dell Inspiron 11-3168 Screen Replacement: step 8, image 3 of 3
    • Find the smaller ZIF connector. Using tweezers, carefully lift the black flap on the connector to release the ribbon cable.
  9. Dell Inspiron 11-3168 Screen Replacement: step 9, image 1 of 2 Dell Inspiron 11-3168 Screen Replacement: step 9, image 2 of 2
    • Disconnect the webcam module located at the top of the monitor.
  10. Dell Inspiron 11-3168 Screen Replacement: step 10, image 1 of 2 Dell Inspiron 11-3168 Screen Replacement: step 10, image 2 of 2
    • Lift and remove the display screen from the top case.
One Comment
how much did this display cost?
Ibrahim Ahmed Mohamed - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 750
