Dell Inspiron 1122 M102z Hard Drive Replacement
  1. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: step 1, image 1 of 1
    • Follow the instructions in Before You Begin.
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 1122 M102z Hard Drive Replacement, Disconnecting the Hard Drive: step 2, image 1 of 1
    • Using the pull-tab, slide the hard-drive assembly to the side to disconnect it from the connector on the system board.
  3. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 1122 M102z Hard Drive Replacement, Remove the Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 1122 M102z Hard Drive Replacement, Lifting the Hard-Drive Bracket: step 5, image 1 of 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard Drive: step 6, image 1 of 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 1122 M102z Hard Drive Replacement, Placing the Hard-Drive Assembly: step 8, image 1 of 1
    • Place the hard-drive assembly in the computer base.
  9. Dell Inspiron 1122 M102z Hard Drive Replacement, Sliding the Hard-Drive Assembly: step 9, image 1 of 1
    • Using the pull-tab, slide the hard-drive assembly into the connector on the system board.
  10. Dell Inspiron 1122 M102z Hard Drive Replacement, Replace the Screws: step 10, image 1 of 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 263
