Dell Inspiron 13 7378 Wi-Fi Card Replacement
  1. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Back Cover: step 1, image 1 of 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 2, image 1 of 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 3, image 1 of 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 3, image 2 of 3 Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 3, image 3 of 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 1 of 2 Dell Inspiron 13 7378 Wi-Fi Card Replacement, Wi-Fi Card: step 4, image 2 of 2
    • Remove the single 3 mm screw from the Wi-Fi card using a Phillips #1 screwdriver.
  5. Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 5, image 1 of 1
    • Use your fingers to pull the Wi-Fi card upwards from the slot of the motherboard.
    • Take caution in pulling out the Wi-Fi card; two cable connectors are still attached.
  6. Dell Inspiron 13 7378 Wi-Fi Card Replacement: step 6, image 1 of 1
    • Disconnect the two wires attached to the Wi-Fi card.
    • Remove the Wi-Fi card from the laptop.
Samantha Gonzalez
298 Reputation
2 Guides authored
Gateway, Team 1-3, Saknee Spring 2022 Member of Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 278
