Dell Inspiron 13 N3010 Hard Drive Replacement
  1. Dell Inspiron 13 N3010 Hard Drive Replacement, Remove the Screw: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 13 N3010 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: step 2, image 1 of 1
    • Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
  3. Dell Inspiron 13 N3010 Hard Drive Replacement, Lifting the Hard-Drive Assembly: step 3, image 1 of 1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 13 N3010 Hard Drive Replacement, Remove the Four Screws: step 4, image 1 of 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13 N3010 Hard Drive Replacement, Lifting the Hard-Drive Bracket: step 5, image 1 of 1
    • Lift the hard-drive bracket away from the hard drive.
  6. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive: step 6, image 1 of 2 Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive: step 6, image 2 of 2
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 13 N3010 Hard Drive Replacement, Replace the Screws: step 7, image 1 of 1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13 N3010 Hard Drive Replacement, Placing the Hard-Drive Assembly: step 8, image 1 of 1
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron 13 N3010 Hard Drive Replacement, Connecting the Hard-Drive Assembly: step 9, image 1 of 1
    • Slide and connect the hard-drive assembly to the system board connector.
  10. Dell Inspiron 13 N3010 Hard Drive Replacement, Replace the Screw: step 10, image 1 of 1
    • Replace the screw that secures the hard-drive assembly to the system board.
    • Turn over the system board assembly.
Terrence15
79,243 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 700
